TRIANGLE BP400 Banana Plugs Silver Plated Ø2.2mm 3.8mm² (Set x4)
The BP400 Triangle banana plugs ensure both an optimal contact between the cable and the terminal block due to their shape, while ensuring an optimal electrical conductivity. The contacts are silver plated for a perfect signal transmission.
Reference : 15992
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 24-04-2025.
Triangle BP400
Triangle BP400 Fiches Bananes Plaquées Argent 3.8mm²
The BP400 Triangle banana plugs ensure both an optimal contact between the cable and the terminal block due to their shape, while ensuring an optimal electrical conductivity. The contacts are silver plated for a perfect signal transmission. The BP400 can accommodate conductors up to 3.8mm².
Product typeBanana plugs
Contacts platingSilver
Max conductor section3.8mm²
Max conductor diameterØ2.2mm
Body materialAnthracite anodized aluminum
Connector length45mm
Connector body dimensionsØ10 x 26mm
Quantity4 banana plugs (2 with red marking, 2 with black marking)
Max cable diameter (mm)2.2
Mounting typeTo screw
ConnecticMale
ConnectorBanana
2 reviews
Nickel
Ces fiches sont parfaites. Très faciles à mettre en oeuvre et le système de vis permet au câble d'être parfaitement attaché.
This review has been posted for TRIANGLE BP400 Banana Plugs Silver Plated Ø2.2mm 3.8mm² (Set x4)
Excellentes fiches bananes
Excellentes fiches bananes. Elles sont très faciles à installer.
Ne dénaturent pas le son et tiennent fermement sur la fiche HP femelle.
Il faut simplement mieux repérer le Plus et Moins.
Je recommande vivement ces fiches avec le câble triangle.
Envoi rapide comme d'habitude par l'équipe.
The BP400 Triangle banana plugs ensure both an optimal contact between the cable and the terminal block due to their shape, while ensuring an...
