VIABLUE T6s Banana Plug Gold Plated Ø9.5mm (Set x4)
Viablue T6s banana plugs offer excellent design quality for high-performance cable design. Their contact is 24k gold plated offering very good conductivity and resistance to oxidation, and their "sawtooth" shape ensures optimal contact between the connector and the terminal block.
2.5 / 5
Reference : 3139
89,99 €tax incl.
74,99 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
Viablue T6s
Viablue T6s Fiches Banane Plaqué Or Ø9.5mm (Set x4)
Viablue T6s banana plugs offer excellent design quality for high-performance cable design. Their contact is 24k gold plated offering very good conductivity and resistance to oxidation, and their "sawtooth" shape ensures optimal contact between the connector and the terminal block. The body of the connector is made of Aluminium. Mounting is extremely simple with an M4 hexagon socket screw.
The main feature of this connector is to have an interchangeable tip with the other models of the T6s range (sold separately).
All connectors in the T6s range are supplied with 2 diameter reducers. These reducers allow the connectors to better adapt to your cables.
The small gearbox has an outer diameter of 7.5mm and an inner diameter of 4.5mm. Thus, cables with a diameter of 3mm to 4.5mm can be mounted securely.
The large reducer has an outer diameter of 9.5mm and an inner diameter of 7.5mm and cables with a diameter of 5mm to 7.5mm can be securely mounted on it.
Without reducer, cables with a diameter of 7.5mm to 9.5mm can be installed.
Product typeBanana plug
Contact platingGold 24k
Connector diameterØ13.5mm
Connector body length30.5mm
Banane plug contact length18.6mm
Max cable diameterØ 3 - 9.5mm
Connection typeTo solder
To screw (hexa screw M4 1.5mm)
Inner soldering tub diameterØ5mm
Body materialAluminium
Interchangeable contact tip
ColorBlack and golden
QuantitySold by set of 4 banana plugs
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
ConnectorBanana
2 reviews
BUONO
Qualità costruttiva buona, avrei preferito fissaggio cavo con viti a brugola
Consegna veloce
This review has been posted for VIABLUE T6s Banana Plug Gold Plated Ø9.5mm (Set x4)
Autant les câbles ont l'air 'être bien, autant ces fiches sont déroutantes, énervantes, pas pratiques, erreur monumental en commandant ça ! A lui préférer et de loin des Real Cable à 2x visse, tout simplement !!
Les fiches de modulation, pas loin du même raisonnement !
Viablue T6s banana plugs offer excellent design quality for high-performance cable design. Their contact is 24k gold plated offering very good...
