Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You can also screw these plugs to the body of Viablue T8 banana plugs, allowing you to replace faulty connectors, for example.
Product type | Banana plugs |
Contact plating | Or 24k |
Connector diameter | Ø4mm |
Connector body length | 35mm |
Banane plug contact length | 18.6mm |
Inner soldering tub diameter | Ø5mm |
Package | Sold by 4 |
Max cable diameter (mm) | 5.0 |
Mounting type | To weld |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
