VIABLUE T8 Banana Plug Gold Plated (Set x4)
Viablue T8 banana plugs offer excellent design quality for high-performance cables. Their contact is plated with 24k gold for excellent conductivity and resistance to oxidation. The connector body is made of aluminum. Assembly is extremely simple, thanks to an M4 hexagon socket screw.
Reference : 20488
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2025.
Viablue T8 Banana Plug Gold Plated Ø9.5mm (Set x4)
Viablue T8 : Front view
Viablue T8: Diameter reducers
Connectors in the T8 range are supplied with 2 diameter reducers to enable the connectors to better adapt to your cables. As a result, you can mount these connectors on cables with diameters ranging from Ø3mm to Ø9.5mm.
Viablue T8 : Diameter reducer
Product typeBanana plug
Contact platingGold 24k
Connector diameterØ13.5mm
Connector body length30.5mm
Banane plug contact length18.6 mm
Min-max cable diameterØ3 - 9.5mm
Connection typeTo solder
Inner soldering tub diameterØ4.5mm
Body materialAluminum
ColorBlack and golden
PackageSet x4
Max cable diameter (mm)9.5
Mounting typeTo weld
Mounting typeTo screw
ConnecticMale
ConnectorBanana
VIABLUE T8 Banana Plug Gold Plated Ø9.5mm (Set x4)
Viablue T8 banana plugs offer excellent design quality for high-performance cables. Their contact is plated with 24k gold for excellent...
