VIABLUE T8 Contacts Banana Plugs (Set x4)
New
Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You can also screw these plugs to the body of Viablue T8 banana plugs, allowing you to replace faulty connectors, for example.
Reference : 20716
47,90 €tax incl.
39,92 € tax excl.
Viablue T8 Contacts Banana Plugs Gold Plated Ø5mm (Set x4)
Viablue T8 : Front view
Viablue
Product typeBanana plugs
Contact platingOr 24k
Connector diameterØ4mm
Connector body length35mm
Banane plug contact length18.6mm
Inner soldering tub diameterØ5mm
PackageSold by 4
Max cable diameter (mm)5.0
Mounting typeTo weld
ConnecticMale
ConnectorBanana
VIABLUE T8 Contacts Banana Plugs Gold Plated Ø5mm (Set x4)
Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You...
