J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
Gold Plated Ø8mm (Set x4)
These Viborg banana plugs benefit from a nice design quality and a low price. The contacts are made of a gold-plated copper alloy ensuring good conductivity and durability. The body is made of aluminum. Each plug can accept cables up to 8mm in diameter. Mounting is very simple thanks to a screw system.
Product type | Banana plugs |
Contacts material | Copper alloy |
Contacts plating | Gold |
Body material | Aluminum |
Max cable diameter | Ø8mm |
Max conductor diameter | Ø4.5mm |
Mounting type | To screw |
Dimensions | 46.7 x 10.7mm |
Quantity | Sold by 4 (2x red / 2x black) |
Max cable diameter (mm) | 8.0 |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 4.8 / 5 13 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cedric J.
Cedric J.
Eemeli T.
Everaldo R.
