VIBORG VB401G Pure Copper Banana Plug Silver / Gold Plated 24k 3μ Ø4mm (Set x4)
With its VB-401 (G), Viborg offers exceptional banana plugs, thanks to a design using particularly high-end materials.
4.9 / 5
Reference : 12740
36,90 €tax incl.
30,75 € tax excl.
Shipping date: 21-02-2025.
Viborg VB401G
Banana Plug Pure Copper Gold & Silver Plated ⌀4mm
viborg VB401G fiche banane cuivre pur plaquage or argent
Thus, the contact material of the banana plug is Pure Copper. A first point that attracts attention, copper being an excellent conductor. But Viborg goes further by offering a 3µ 24K gold plating. Gold therefore contributes to the conductivity of the signal but above all protects the connector against oxidation, ensuring a longer service life. Viborg also incorporates a silver sub plating in its connectors. This, always in the same perspective, allows to maximize the conductivity of the connector, Silver being the best conductor.
In short, these banana plugs are totally adapted to fit into a high-end HiFi audio system.
ConductorPure Copper
3 Layer PlatingOFC Copper
Silver
Gold 24K 3µ
ConnectionTo screw (hexagonal socket screw 2mm)
Max cable diameter4mm
DiametersBody : 8.9mm
Contact : 4mm
Length43mm
Max cable diameter (mm)4.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
7 reviews
Excellentes !!!!
Montées sur de l'elecaudio hp25OCC, j'ai pas trouvé mieux que les viborg... idem sur de l'atohm zef max. Je pense que c fiches bananes plaqués argent/or sont neutres comparé aux viborg tout cuivre qui amènent un brin de chaleur. Dans tous les cas, rapport qualité prix imbattable !!!
This review has been posted for VIBORG VB401G Pure Copper Banana Plug Silver / Gold Plated 24k 3μ Ø4mm (Set x4)
Gilbert
Le placage or ne tient pas . Ceci étant constaté après une seule utilisation sur bornier Jantzen carbone .
Excellente fiche banane
Je les ai choisit parce qu'elles sont intérieurement en cuivre pur (et plaqué or). Elle se combine trés bien au bornier Vibrorg BP613, également en cuivre pur. Elle fonctionne aussi trés bien avec le bornier Eizz EZ-303. Avec ces deux borniers, et neuf, la force de serrage/contact de la banane dans les borniers est bonne, et même une des meilleurs que j'ai eut. Aprés un mois d'utlisation, la force de serrage/contact est la même. Coté mesure, j'ai une résistance de contact de 0.08mΩ à 0.10mΩ, la plus basse que j'ai eut dans les mains pour le moment. Coté écoute, c'est impeccable! Le trou pour le cable est un peu grand, ce qui est fréquent... En conclusion, j'ai voulut des fiches bananes avec de bon matériau et une faible résistance de contact, c'est réussit pour moi!
Superbes
Fiches conformes à mes attentes, belle finition, tiennent très bien dans les borniers.
Excellent rapport qualité prix.
Seul petit bémol, pour du 2,5 mm2 le diam intérieur de 5 mm est un peu grand, à quand les fiches avec diam variable en fonction de la section des câbles.
Ce détail existe bien pour les cosses à sertir .
bof bof
les fiches en elles mêmes sont de bonne qualité, on peut l'adapter à beaucoup de types de cable, même les plus fins, en revanche le contact de la banane est défaillant et ce sur les 12 fiches que j'ai installé. les petites lamelles faisant office de ressort ne servent à rien, quand elles ne se font pas la malle , ces fiches sont de mauvaises copies des airlock de chez qed. à mon retour de voyage je commanderai autre chose.
