VIBORG VB404AG Banana Plugs Pure Silver Ø7.5mm (Set x4)
The Viborg VS404AG are a high quality banana plugs for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring maximum conductivity.
Reference : 17333
169,00 €tax incl.
140,83 € tax excl.
Viborg VB404ag
Viborg VB404AG Fiches Bananes Argent Pur Ø7.5mm (Set x4)
The Viborg VS404AG are a high quality banana plugs for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring maximum conductivity. The body of each fork is made of aluminum and carbon fiber, giving the whole an excellent durability. The assembly is done simply with a double screw system allowing an effective maintenance of the cable.
Product typeBanana plugs
Conductor materialPure silver (99.98%)
Shell materialAluminum and carbon fiber
Mounting typeTo screw
Max cable diameterØ7.5mm
Total dimensions57*Ø14.7mm
Shell length23.4mm
Quantity4* banana plugs (2* with red rings, 2* with black rings)
Max cable diameter (mm)7.5
ConnecticN/A
ConnectorBanana
Contacts Material (Connector)Silver
The Viborg VS404AG are a high quality banana plugs for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring...
