WBT-0610Ag Banana Fasteners Angled Locks Silver 10mm² (Set x4)
By buying this product you get 28 loyalty points
Reference : 5262
285,00 €tax incl.
237,50 € tax excl.
Shipping date: 17-04-2025.
Built on the recipes that have made the esteem of the WBT-0645 reference angled banana cards popular, the model WBT-0610Ag performance even further with the use of Money and an insulation Makrolon ®.
Provided with a key ensuring a secure connection conforming to CE standards the most demanding.
Extremely compact and easy to install thanks to its angle of 45 °, the WBT-0610Ag adapts to the most problematic configurations due to the lack of space or the positioning of the terminal blocks.
The tightening of the cable, with a maximum cross section of 10 mm², is carried out using 2 Torx screws ensuring constant pressure throughout the stripped portion for optimal contact.
Features:
  • Silver Contacts
  • Insulation Makrolon ®
  • Tightening the cable with 2 screws Torx ™
  • CE-compliant detonator (can be easily removed)
  • Angle of inclination: 45 °
  • Maximum permissible cross section: 10mm²
  • Overall length: 44 mm
  • Outside diameter: 12.5 mm
  • Sold by 4
  • Mark: 2 x red / 2 x white
Max cable diameter (mm)10.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
Contacts Material (Connector)Silver
