A savoir : les vis de serrage de câble sont des Torx de 5.
Donc prévoyez l'outil spécifique...
Banana Plug Gold plated Alloy Copper ⌀6 (Pair)
These BS-106ZAG banana plugs from WM-Audio will allow you to offer your speaker cables aesthetic and convenient connectors. In addition, designed in gold plated alloy copper, they will provide excellent signal conductivity and will be resistant to oxidation.
The connectors have a double clamping system with two tprx screws for optimal support of your cable. In addition, the central contact may expand to increase its contact area.
Material | Gold plated alloy copper |
Fixing type | To screw |
Input diameter (cable) | 6mm |
Total length | 57mm |
External diameter | 11.6mm |
Double clamping | Yes |
Screw type | Torx |
Weight (1 connector) | 18g |
Sold by pair | 1x red 1x black |
Max cable diameter (mm) | 6.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 4.6 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Robin V.
Emmanuel l.
Eric B.
Gilles C.
