WM AUDIO BS-108 Banana Plug Gold plated Copper Ø6mm (Pair)
These BS-108 banana plugs from WM-Audio in gold plated copper offer very good conductivity and will allow you to offer your speaker cables aesthetic and practical connectors.
4.0 / 5
Reference : 12701
8,90 €tax incl.
7,42 € tax excl.
WM-Audio BS-108
Banana Plug Gold plated Copper ⌀6 (Pair)
Fiches bananes WM-Audio BS-108
These BS-108 banana plugs from WM-Audio will allow you to offer your speaker cables aesthetic and convenient connectors. In addition, designed in gold plated copper, they will provide excellent signal conductivity and will be resistant to oxidation.
The connectors have a double clamping system with two torx screws for optimal support of your cable. In addition, the central contact may expand to increase its contact area.
MaterialGold plated copper
Fixing typeTo screw
Input diameter (cable)6mm
Max cable section8mm²
Total length57mm
External diameter11.6mm
Double clampingYes
Screw typeTorx
Weight (1 connector)19g
Sold by pair1x red
1x white
Max cable diameter (mm)6.0
Mounting typeTo screw
ConnecticMale
Attention au type de vis
Objet conforme à la description.
Justement, il faut bien noter que les vis sont de type TORX et que cela nécessite un tournevis ou une clé que vous n'avez certainement pas chez vous, en tout cas pour cette taille !
(j'ai commandé 6 fiches bananes 4 étaient avec des torx et 2 avec des vis classiques...)
This review has been posted for WM AUDIO BS-108 Banana Plug Gold plated Copper Ø6mm (Pair)
These BS-108 banana plugs from WM-Audio in gold plated copper offer very good conductivity and will allow you to offer your speaker cables...
