WM AUDIO HB301Z Modular Connector Body Ø6mm (Pair)
This connector can be adapted to any situation thanks to the optional screw-in plugs.
Strong points :
  • High quality of conception
  • Compatible with two types of banana plugs
  • Compatible with 9mm fork spacing
Reference : 4474
5,80 €tax incl.
4,83 € tax excl.
This connector for loudspeaker is very efficient. Its screw thread allows the adaptation on 3 different types of compatible plugs in option:
You can thus have the desired connection according to the speakers and amplifier terminals you have. This way, the connectors can be adapted to any situation.
Specifications:
  • 24k Gold plated contacts
  • Mounting type: to screw
  • Input diameter: 6mm
  • Total length: 38mm
  • Outer diameter: 11.5mm
  • Sold by pair
  • Marking: 1x rouge / 1x blanc
https://www.audiophonics.fr/images2/4474/4474_wmaudio_HB301Z_2.jpg
https://www.audiophonics.fr/images2/4474/4474_wmaudio_HB301Z_1.jpg
Compatible with the following banana or fork terminations:
W&M Audio HEAD-B301G Banana Terminations:
https://www.audiophonics.fr/images2/4475_W&MAUDIO-Head-B301G_2.jpg
W&M Audio HEAD-HB301G Banana Terminations:
https://www.audiophonics.fr/images2/4476_W&MAUDIO-Head-HB301G_1.jpg
Terminaisons Fourches W&M Audio HEAD-K301G :
https://www.audiophonics.fr/images2/4477_W&MAUDIO-Head-K301G_1.jpg
Max cable diameter (mm)6.0
Mounting typeTo screw
ConnecticFemale
ConnectorBanana
This connector can be adapted to any situation thanks to the optional screw-in plugs. Strong points : High quality...
