IMR26650 Lithium-Ion 26650 Battery cell 3.7V 5200mAh Rechargeable
This massive battery format can both be used with devices that require long battery life and devices that require high energy discharge (15A max).
Reference : 13667
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
26650 IMR battery
Warning: these batteries do not have electronic protection circuit. It must be used with a BMS (Battery Management System) capable of interrupting the charging and discharging depending on the state of the cell. You will find such a circuit with battery cradle and connectivity here..
This 26650 battery is ideal for projects that require a transportable power supply. This massive battery format can both be used with devices that require long battery life and devices that require high energy discharge (15A max).
Thanks to their ease of use, the individual batteries of this type are particularly appreciated in the DIY scene. Easily interchangeable and renewable, they make effective, long-lasting and economical power solutions.
26650 jab audiophile wondom hi imr accumulator
TypeAccumulator
Format26650 (cylindrical)
Capacity5200mAh
RechargeableYes
ChemistryLithium Ion (IMR)
Nominal voltage3.7V
Max voltage4.2V
Min Voltage2.5V
Max discharge current15A
ConnectorFlat Top
Dimensions26.8 x 66.7mm (+/- 0.2)
Weight95.0g
Package Contents
battery 26650x1
Rated voltage (V)3.7
2 reviews
Good capacity and duration.
This review has been posted for IMR26650 Lithium-Ion 26650 Battery cell 3.7V 5200mAh Rechargeable
Fait son Job
RAS, bon accu Lithium-Ion
