LG ELECTRONICS NR18650 Lithium-Ion Accumulator 18650 Battery 3.6V 3350mAh Rechargeable
This Lithium-Ion battery type 18650 from LG Electronics is ideal for providing clean, stable and quiet power to devices of equivalent voltages and currents. It can for example power some small Class D amplifiers such as some JAB from Sure Electronics or integrate into the design of portable portable speakers, being rechargeable.
4.0 / 5
Reference : 13078
7,90 €tax incl.
6,58 € tax excl.
3 >Month warranty
LG Electronics NR18650F1L
 Lithium-Ion 18650 Battery 3.6V 3350mAh Rechargeable
LG Electronics NR18650F1L Batterie Lithium-Ion 18650 3.6V 3350mAh Rechargeable
In order to use this battery, it is possible to associate it with the Battery Charger 18650 Sure AA-JA11113 or the module for Lithium batteries 18650 Allo Battery Pack.
TechnologyLi-Ion
Type18650
ConnectorFlat Top
Voltage rating3.6V
Capacity3350mAh
Standard discharge current650mA (0.2C)
Max discharge current4.875A (1.5C)
External dimensions18.3 x 65.1mm
InputNC
OutputNC
Input voltage (V)N/A
Rated voltage (V)3.6
Great capacity.
The capacity is very nice, but this is based on older technology and you can not draw lots of current continuously.
On my builds, when the battery gets to about 25% I need to turn the volume down. Continuing to play at or near max level will cause the BCPB3 to enter protection mode. It stops any current and I need to connect it to the charger for 1 second or so to bring it back On.
This is most likely due to the battery dropping voltage too much under higher load, causing the undervoltage protection to kick in, even though, you are actually well above 3v for each cell.
This review has been posted for LG ELECTRONICS NR18650 Lithium-Ion Accumulator 18650 Battery 3.6V 3350mAh Rechargeable
This Lithium-Ion battery type 18650 from LG Electronics is ideal for providing clean, stable and quiet power to devices of equivalent voltages and...
