LR21700SF Lithium-Ion Battery 21700 3.7V 4500mAh Rechargeable
This LR21700SF type 21700 lithium-ion battery is ideal for providing a stable, clean and noiseless power supply for your devices requiring equivalent voltage and current, or for parallel series integration in a power supply module. This battery has a capacity of 4500mAh at a nominal voltage of 3.7V, with a constant maximum discharge current of 13.5A.
Reference : 18489
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 06-10-2026.
3 >Month warranty
LR21700SF Lithium-Ion Battery 21700 3.6V 4500mAh Rechargeable
This battery is ideal for the WONDOM BCPB6 battery manager module.
Product typeLithium-ion battery
Batterie type21700
ConnecteorFlat Top
Rated voltage3.7V
Rated capacity44000-4600mAh
Final load voltage4.2V
Final discharge voltage2.75V
Max. discharge current (constant)13.5A
Max. discharge current (pulse)15A-25A
Charging current0.xx 2A
BMS protection
Operating temperature at load0°C - 45°C
Discharge operating temperature-20°C - 50°C
Loading processCV CC
Diameter21.7mm (± 0,2 mm)
Height70,9mm (± 0,2 mm)
Weight69g (± 2g)
Package1x rechargeable Lithion-ion battery LR21700SF
Rated voltage (V)3.7
This LR21700SF type 21700 lithium-ion battery is ideal for providing a stable, clean and noiseless power supply for your devices requiring...
