PANASONIC NCR18650BD 18650 Battery
This 18650 Lithium-Ion battery from Panasonic is ideal for providing clean, stable, noise-free power to devices of equivalent voltage and current. For example, it can be used to power small Class D amplifiers such as Sure Electronics JABs, or as a rechargeable power supply for portable speakers.
Reference : 20381
5,90 €tax incl.
4,92 € tax excl.
Panasonic NCR18650BD 18650 Accumulator Lithium-Ion Battery 3.6V 3180mAh Rechargeable
Photo of Panasonic NCR18650BD battery pack
To use this battery, you can combine it with the Sure AA-JA11113 18650 battery charger or the Allo Battery Pack 18650 lithium battery module.
Panasonic battery measurements
Product typeLithium-Ion battery
Type18650
ConnectorFlat Top
Typical capacity3180mAh
Min. capacity3080mAh
Nominal capacity300mAh
Nominal voltage3.6V
Final charging voltage4.2V
Final discharge voltage2.5V
Charging curentmax. 1.5A
Max. current output10A (10000mA)
Charging methodCC-CV
DiamèterØ18.50mm (± 0.1mm) + 65.30mm (±0.15mm)
Weight49.5g (±1g)
Package1x Panasonic NCR18650BD 18650 Lithium-Ion battery
Rated voltage (V)3.6
PANASONIC NCR18650BD 18650 Accumulator Lithium-Ion Battery 3.6V 3180mAh Rechargeable
This 18650 Lithium-Ion battery from Panasonic is ideal for providing clean, stable, noise-free power to devices of equivalent voltage and current....
