LiFePO4 3.2-3.3V 2000mAh
This IFR22650 battery with a LiFePO4 (Lithium-Iron-Phosphate) chemical composition offers a nominal voltage of 3.2V-3.3V and a capacity of 2000mAh. Durable, it can be subjected to 1000 charging cycles. LiFePO4 batteries have the advantage over conventional Li-Ion batteries of being more durable (higher number of charging cycles), less sensitive to partial charges and withstanding higher currents. They are also more reliable and the voltage delivered during discharge is more stable. These batteries are also less polluting and can be stored for a longer period of time.
Batteries provide your devices with a clean, stable and noiseless power supply. For example, they can power some HiFi modules or be integrated into the design of portable mobile speakers.
Product type | Rechargeable battery |
Capacity | 2000mAh |
Voltage rating | 3.2-3.3V |
Discharge voltage | 2V |
Max. continuous discharge | 3C 6A |
Charging current | 0, xx - 2.00A |
Charging voltage | 3.65V |
Positive pole | Flat |
Chemical composition | LiFePO4 |
Diameter | Ø22.1 +/-0.25mm |
Height | 65 +/-0.3mm |
Connector | Flat top |
Weight | 63g |
Charging method | CC-CV |
