TRUSTFIRE Lithium-Ion 18650 Battery 3.7V 3400mAh Rechargeable
This Trustfire 18650 Lithium-Ion battery has a capacity of 3400mAh and a nominal voltage of 3.7V. It will provide your devices with a perfectly clean and stable power supply. What's more, it features a complete protection system (PCB 7A) against overvoltage, undervoltage, short-circuit and reverse polarity.
Reference : 18384
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
Trustfire Battery
Lithium-Ion 18650 3.7V 3400mAh Rechargeable
Trustfire Accumulateur Lithium-Ion 18650 3.7V 3400mAh Rechargeable
Please note battery dimensions. Due to the integrated electronics for the protection system, the height and diameter are greater than those of a standard 18650 battery without PCB system.
Product typeBattery
ChemistryLithium-Ion
LiNiCoAlO2
Format18650
Capacity3400mAh
Minimum capacity3250mAh
Rated voltage3.6V - 3.7V
Charging end voltage4.20V ±0.03V
Final discharge voltage2.50V
Charging current0.100A - 1.62A
ProtectionIntegrated PCB 7A
Positive poleRaised (button top)
Diameter18.4mm ±0.1mm
Height68.9mm ±0.15mm
Weight48g
Charging methodCC-CV
InputNC
OutputNC
Input voltage (V)N/A
Rated voltage (V)3.6
This Trustfire 18650 Lithium-Ion battery has a capacity of 3400mAh and a nominal voltage of 3.7V. It will provide your devices with a perfectly...
