WONDOM BCPB6 Battery Management Module
This Wondom BCPB6 battery manager module lets you use 6 cells (lithium-ion battery) 21700 to power your electrical devices. The module enables you to achieve a considerable level of autonomy while maintaining a fairly compact form-factor with up to 88W/h to 100W/h of energy. The board's extensive connectivity makes integration quick and easy.
Reference : 18455
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 06-10-2026.
WONDOM BCPB6
Battery Manager Module 6x21700
WONDOM BCPB6 Battery Manager Module 6x21700
To guarantee a high level of reliability, the module is equipped with a complete protection circuit: overcurrent, overtemperature, short-circuit, overvoltage and undervoltage protection.
Two power supply options
The module can be powered from 5V to 24V DC via a 5.5/2.1mm DC jack connector. It requires a current of between 0.90A minimum and 2.5A maximum.
A Wago connector can also be used to connect a solar charging source from 18.3V to 24V.
Multiple discharge ports for a wide range of applications
Different discharge ports are available on the BCPB6 module. They are all connected in parallel for identical functions. The module can be used to power several devices at the same time. The discharge ports are as follows: Molex Minifit, Molex Microfit JST PH and JST XH.
LED indicators
Connectors for LED battery level indicators are available, so you can keep track of the module's operating status even when it's integrated in a case.
6 accumulators 21700
This module is designed to accommodate 6 high-capacity 21700 batteries simultaneously. This means 6x 4000mAh for an extremely comfortable total capacity. This configuration also enables high voltages to be reached, with current outputs of 1x 4A (J13: JST-PH), 3x 9A (J15: Molex microfit / J12: JST-XH / J14: Molex Minifit) and 1x 12V 3A (J4: JST-PH).
La connectique du module Wondom BCPB6
Charge
  • J3 : DC5.5/2.1mm jack connector for 5V-24V AC adapter
  • J2 : WAGO-2060 4mm 2-pin connector for 19V-24V solar power supply
Décharge
  • J12 : JST-XH 2.5mm connector 16.8-25.2V DC
  • J13 : JST-PH 2mm connector 16.8-25.2V DC
  • J14 : Molex Mini-Fit connector 16.8-25.2V DC
  • J15 : Molex Micro-Fit connector 16.8-25.2V DC
  • J4 : JST-PH 2mm 12V DC connector(activate voltage regulator with switch SW1)
Autres
  • J10 : PH-2mm connector for external charging port LED indicator
  • J11 : PH-2mm connector for external power port LED indicator
  • J25 : External port for LED battery level indicator
  • A : LED battery status indicator (Press SW2 to check battery level)
Product typeBattery management system
Supported batteriesLithium-ion
6x 21700
4000 mAh
Input power supplyJack DC input (J3): 5V to 24V DC
Solar panel input (J2, wago 2060): 19V DC
Output currentJST-PH (J13): 4A (peak current 8A for 200ms)
Molex Micro-Fit (J15): 9A (peak current 12A for 200ms)
JST-XH (J12): 9A (peak current 12A for 200ms)
Molex Mini-Fit (J14): 9A (peak current 12A for 200ms)
JST-PH (J4): 12V 3A (12A peak current for 200ms)
Charge current0.9V
Protection against excessive discharge (detection / loosening)Yes - individual protection for each battery
Protection against overload (detection / loosening)Yes - individual protection for each battery
Initial equilibrium batteries4.18V
Maximum Operating Temperature50°C (20°C ideal)
Dimensions152.4 x 114.3mm
Mounting holes142.24 x 104.14mm
Weight152g
Package1x WONDOM BCPB6 battery manager module
1x JST-PH 4-pin cable
InputPCB Connector
OutputPCB Connector
Output voltage (V)NC
Output current (A)4.0
Output current (A)3.0
Output current (A)9.0
Input voltage (V)24.0
Input voltage (V)5.0
Input voltage (V)19.0
Input voltage (V)12.0
Power SupplyBattery
WONDOM BCPB6 Battery Management Module 6x21700
This Wondom BCPB6 battery manager module lets you use 6 cells (lithium-ion battery) 21700 to power your...
