WONDOM PS-BC12114 BCPB0 Power Supply on Battery BMS / Charger Module Lithium 26650 with Protections
Battery cradle module 1x 26650 with protected USB-A output and direct port for power supply and mounting on Raspberry Pi.
Reference : 14116
9,90 €tax incl.
8,25 € tax excl.
Last items in stock !
Shipping date: 23-04-2025.
Wondom PS-BC12114 BCPB0
Battery Management supply Raspberry Pi accumulator 26650
The battery manager BCPB0 provides a high performance circuit to ensure the charge and protection of your lithium batteries. Completely secure, it supports the protection against overload, overheating, short-circuit and over-discharge of the battery.
It embeds a battery cradle for 1x 26650 cell and constitutes a compact external battery Raspberry Pi / Smartphone / tablet through its female USB-A discharge port.
A LED indicator shows the state of charge and discharge of the battery.
Optimized for Raspberry Pi
battery power raspberry pi battery UPS battery
Integration with a Raspberry Pi can be pushed even further with a cleverly designed connector to attack the GPIO in direct contact from below. This will feed a Raspberry Pi even in a very space-limited environment while leaving the 40-pin GPIO available for other applications. It is an ideal choice for your projects of DAC / streamer nomadic and semi-nomadic devices based on SBC.
Dimensions
IndexDimensions
A91.52 mm
A157.91 mm
A226.16 mm
B30.48 mm
B123.11 mm
D12.79 mm
D24.32 mm
TypeBattery Manager
Battery formatLithium accumulator 26650
Number of batteriesx1
Batteries included?No
Output voltage5VDC
Max discharge current2A
Maximum load current2A
Minimum load current1A
Overload detection voltage4.235V
Overload release voltage4.18V
Over-discharge detection voltage2.8V
Over-discharge release voltage3V
Maximum Operating Temperature50 ° C
InputNC
OutputUSB
OutputPCB Connector
OutputSolder pad
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)N/A
Power SupplyBattery
Nouveau connecteur
Parfait pour alimenter un raspbery zero pendant des heures
Quel est le type de connecteur présent sur la carte (facilite son branchement)) ?
This review has been posted for WONDOM PS-BC12114 BCPB0 Power Supply on Battery BMS / Charger Module Lithium 26650 with Protections
