WONDOM PS-BC12115 BCPB1+ Battery BMS Power Supply / Charger Module Lithium 26650 with Protections
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 26650 and has two slots as well as a complete protection system. It also operates with a wide input voltage range, from 5VDC to 19VDC. The batteries, connected in series, provide 30-40Wh of power. The integrated MPPT charging function supports a 19-24V power supply.
Reference : 16328
14,90 €tax incl.
12,42 € tax excl.
Wondom BCPB1+
Wondom BCPB1+ Chargeur de Batterie Lithium 26650 avec Protections
The module is completed with a battery level display. The cycle-by-cycle protection system avoids problems with overcurrent, overheating, short circuits and over/under voltage. In addition, the integrated battery balancing circuit maintains a constant voltage between the two cells.
Li-Ion batteries are sold separately.
Module operation
Wondom PS-BC12111 BCPB1+ Module BMS d'Alimentation / Chargeur de Batterie Lithium 26650 avec protections
Product typeBMS Board
Supported cellsLi-Ion 26650
ProtectionsOverloads / Over-discharges
Overcurrents
Overheating
Solar charging compatibilityYes
Number of battery slots2
Charge indicatorsYes
Supply voltage5-19VDC
Charge current1.5A
Package1x Wondom PS-BC12115 BCPB1+
1x XH 4 pins cable
Measurements
ParameterConditionsMin.Typ.Max.
Supply voltageUSB-C (J13) and JST-PH (J7)5VDC-19VDC
Solar panel input,Molex Micro-Fit(J2 ) through a diode14VDC19VDC24VDC
Supply currentSupply current at both wide input range,Type-C Jack (J13) and JST-PH(J7)are limited by boost circuit only, so typical current limitations are same0.8A1.5A2.1A
Output currentUSB-A (J14)-2A3A
Molex Micro-Fit (J6)-2A3A
Charge currentPre-charge current (0-140mA) might take hours before going to constant current charge mode at 1.5A typical. The charging current decreases dramatically after reaching constant voltage mode which start at 4.2V. The maximum charge current can only be obtained if Iin: 2.1A, Vin: 7.5V are supplied to the board. Charge current decreases if lower input current and voltage applied to the board1.5A – 15%1.5A1.5A + 15%
Battery capacityUse 5000mAh to get the typical value. Refer battery’s user manual   if you are using your own batteryBatteries Lithium-Ion 5000mAh
Overcharge detection voltage (per cell)Once overcharge triggered, users are supposed to wait till voltage drops to over voltage release voltage and activate again for normal use4.19V4.24V4.29V
Overcharge release voltage (per cell)4V4.05V4.1V
Over-discharge detection voltage (per cell)Power up this board through Type-C Jack (J13) or JST-PH(J7) to activate if the board goes into protection mode or for initial use2.72V2.8V2.88V
Over-discharge release voltage2.9V3V3.1V
Opreating temperature range-0°C20°C50°C
InputPCB Connector
OutputPCB Connector
Output voltage (V)NC
Output current (A)3.0
Output current (A)2.0
Input voltage (V)5.0
Input voltage (V)19.0
Power SupplyBattery
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 26650 and has two slots as well as a...
