CANARE 4S8 STAR QUAD Speaker cable Copper 4x1.3mm² Ø8.3mm
Here the cable CANARE 4S8, cable perfect speaker for bi-wiring quality and affordable. It has 4 conductors in high quality copper, with a very long life.
4.7 / 5
Reference : 13034
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 22-04-2025.
Cable 4S8 Canare speaker cable
The canares cables are among the best cables to connect the speaker to its amplifiers.
Here the cable CANARE 4S8, cable perfect speaker for bi-wiring quality and affordable. It has 4 conductors in high quality copper, with a very long life. Its isolation in PE (polyethylene) and configuration "Star Quad" single confers protection against electromagnetic interference (EMI) that can be emitted from the speakers.
You can use it naked if you want it add endings we recommend forks and similar quality bananas with Copper OFC oxygen-free, for example.
number driversx4
conductive materialannealed copper
sectional area4x 1.31 mm² (16AWG)
total diameterØ8.3mm
Isolationpolyethylene
BodyPVC (flexible)
sheath colorBlack
Soldthe meter
Mechanical characteristics
Model4S8
Weight / meter0.19kg
overall diameter8.3 mm
PCV sheath thickness1.1 mm
Brittle pint-49°C
Number of conductorsx4 (Red, clear Red, White, clear White)
InsulatingPE
0.5 mm
Conductor - AWGAC
# 16
# 13 (combined biwiring)
Quad Cable pitch70 mm
electrical performance
Model4S8
Cond. D.C.R.1.5 ohm / 100 m
Nominal capacitance between red and white wires145 pF / m
Diameter (mm)8.3
Length (m)Sold by length
Number of conductors4
Insulation materialPE
ShieldingNo
Section (mm²)1.31
Ground / ShieldingNo
3 reviews
Color
Expected one with a gray jacket as in the picture.
Got a black one instead.
Conducts electricity anyway.
This review has been posted for CANARE 4S8 STAR QUAD Speaker cable Copper 4x1.3mm² Ø8.3mm
Presque parfait
Utilisé avec système vintage ampli Dual cv1260 enceintes D56 audio référence. Source streaming Hd tidal avec wtx Microstreamer.
Comparé à mes câbles cuivre 2,5 mm2 : plus de précisions et de détails et surtout une image sonore incroyable ... la musique remplit ma pièce.
Mais des aigus très présents qui fatiguent un peu donc je pense chercher encore le câble idéal.
Bon câble
Bonne qualité, malgré une certaine rigidité qui pourrait gêner dans certaines utilisations.
Here the cable CANARE 4S8, cable perfect speaker for bi-wiring quality and affordable. It has 4 conductors in high quality copper, with a very long...
