MOGAMI W3104 OFC Copper Speaker Cable 4x4.0mm² Ø 14.5mm
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of 4mm² (12AWG) and has an efficient PVC insulation.
Reference : 5240
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 22-01-2025.
Mogami 3104
MOGAMI 3104 Câble HP Cuivre OFC 4x4.0mm² Ø 14.5mm
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of 4mm² (12AWG) and has an efficient PVC insulation. It therefore ensures excellent conductivity of the audio signal while considerably limiting interference and therefore parasitic noise. It thus ensures a precise and transparent signal reproduction. The PVC sheath also provides very good flexibility for easy assembly and installation.
The connection of the conductors in diagonal pairs considerably reduces the mutual inductance.
Product typeSpeaker cable
Conductors number4
Conductors materialOFC Copper
Conductors section4mm² (12AWG)
Cable diameter14.5mm
Insulation / sleeve materialPVC
DC Resistance(20°C)0.005 Ohm/m
Inductance (1kHz, 20°C)0.6µH/m
Voltage breakdownMust withstand at 500V DC / 15s
QuantitySold per meter
Diameter (mm)14.5
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
22 reviews
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
This review has been posted for MOGAMI W3104 OFC Copper Speaker Cable 4x4.0mm² Ø 14.5mm
Best purchase ever and best value
I was sceptical enough to just buy 2 times 3 meter cabel without bananas because I did not want to make a bigger investment just to try the cable. That was a mistake. I imediately ordered banana plugs for the cable. I exchanged the cable for a chord company clearway which is almost exactly the same price but the performance of this Mogami is of a completeley another level.
My System is: Audio Note AN-J with a Hegel Röst as amplifier and I use the Dac of the röst with an Pro-Ject streamer.
At the beginning you notice that it is much cleaner sounding but the base was gone and the treble was to bright. After about 10 hours the base came back suddenly and the treble is also not so bright anymore and it is getting better and better now. Just listended 20 hours. Cable needs break in time! Who would belive that a cable needs break in time? Ridiculous. I would not have believed it if you told me but it does need break in time.
Together with a furutech FP-TCS31 my system is on a completely different level. If you would tell me the dac or the amplifer was exchanged for another component of double the price I would have believed it but is was just cable upgrade.
The changes were not subtle at all! Much better system now. Best value ever.
Amazing
I never was into special speaker cables, but I really should have tried this sooner. It really makes a difference, never expected that! I am using these with neutrik 4 wire speakon connector on hypex nc-400 monoblocks with Q-acoutics 3050i. Sounds amazing, much more depth and soundstage, better highs. Using Wiim pro plus with external dac SMSL m500.
Recommended!
Buy with confidence!!
The best Speaker Cable I´ve built so far!
I´ve paired it up with Viborg VB402R connectors with very nice result!
I´ve f.ex. recently built one "RAMM AUDIO AMADEUS 5 MK2" that´s about three times as expensive/meter. Burned the RAMM in with NordOst-equipment, but still it is NOT as musical as my old MOGAMI.
the Mogami is far mor lively and presents music more "real" and with more energy.
It´s just a fantastic cable that I absolutely and with confidence can recommend for all you DIY´rs out there!!
Just remember to order big enough connectors, since this is a large snake.
Excellent
After the long break-in period I can only say that cables are
amazing. I have 5 time more expensive cables but this is pure music. Recommended.
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of...
