NEOTECH NES-3003G Speaker Cable
Neotech's NES-3003G is a cable designed for bi-wiring and bi-amplification incorporating four G-UPOCC composite conductors, a combination of OCC copper and graphene, each with a cross-section of 1.3mm². This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Reference : 19743
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 23-04-2025.
Câble vendu au mètre
Neotech NES-3003G Speaker Cable Graphene Copper G-UPOCC 4x1.3mm² Ø19mm
NEOTECH NES-3003G : Cutaway view
The conductors have PVC insulation, which prevents any transmission of electrical discharge with the braided aluminium shielding, while giving the cable good mechanical strength.
Don't forget to remove the straps from your speaker terminals if you are using bi-wiring or bi-amplification.
Product typeSpeaker cable (bi-wiring option)
Number of conductors4
Conductors materialGraphene copper G-UPOCC
Cable diameterØ19mm
Conductor insulationPCV
Cross-section4x1.3mm²
ShieldingBraided aluminium
ColorGrey
PackageSold by the meter
Diameter (mm)19.0
Insulation materialPVC
ShieldingYes
Section (mm²)5.2
Conductors material (Cable)Graphene
Ground / ShieldingYes
NEOTECH NES-3003G Speaker Cable Graphene Copper G-UPOCC 4x1.3mm² Ø19mm
Neotech's NES-3003G is a cable designed for bi-wiring and bi-amplification incorporating four G-UPOCC composite conductors, a combination of...
