RAMM AUDIO INFINITAS5 Speaker Cable
The Ramm Audio Infinitas5 is a high-end speaker cable that meets the criteria for bi-wiring/amplification.
Reference : 19926
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 23-04-2025.
Câble vendu au mètre
RAMM AUDIO Infinitas5 Speaker Cable Graphene OCC Copper 6x1.5mm² Ø16mm
RAMM AUDIO Infinitas5 picture
The Ramm Audio Infinitas5 is a high-end speaker cable that meets the criteria for bi-wiring/amplification. It features 6 conductors, each composed of 3 x 0.5mm CuGr OCC conductors and 4 x 0.5mm HDPE-shielded CuGr OCC conductors. The 6 main conductors therefore each have a cross-section of 1.5mm², enabling transmission of a substantial signal while avoiding any skin effect. The cable structure is completed by a 3x 0.5mm CuGr OCC drain wire, Air Inside Geometry technology and multilayer shielding (polypropylene and mylar) that effectively protects the Ramm Audio Infinitas5 from EMI/RFI interference while minimizing noise levels. This high-performance speaker cable is ideal for DIY production of high-power cables.
Ramm Audio Infinitas5 structure
La structure du RAMM AUDIO Infinitas5
1Nylon braided sheath
2PVC sheath
3Filling cotton
4Air tube
5Drain wire 3x 0.5mm CuGR OCC
6Al Mylar shielding
70.5mm CuGr OCC
80.5mm CuGr OCC + HDPE
9Al Mylar shielding
10HDPE inner sheath
11PE sheath
Product typeSpeaker câble
Conductors numbers6 x 7x0.5mm stranded conductors
Cross-section7x 0.2mm² per conductor, i.e. 6x1.5mm²
Conductors meterialGraphene OCC copper
ShieldingAl Mylar
InsulationAir inside Geometry + Cotton filling + PVC sheathing
External diameterØ16mm
Electrical characteristics
Inductance1.33μh/m per conductors
Resistance0.03Ω/m per conductors
Capacitance428pF/m per conductors
Weight≃450g/meters
PackageSold by meter
Diameter (mm)16.0
Number of conductors6
Insulation materialPE
Insulation materialPVC
Insulation materialHDPE
ShieldingYes
Section (mm²)1.5
Conductors material (Cable)Graphene
Ground / ShieldingYes
RAMM AUDIO INFINITAS5 Speaker Cable Graphene OCC Copper 6x1.5mm² Ø16mm
