SOMMERCABLE ELEPHANT SPM425 HP OFC cable 4x2.5mm² Ø 10.2mm
4.8 / 5
Reference : 722
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 25-04-2025.
SOMMERCABLE - SC-ELEPHANT SPM425
https://www.audiophonics.fr/images2/722/722_sommercable_Elephant_1.jpg
The cables are red ...
and the crowd roars when the loudspeaker volume is pushed to the maximum. Such a climax does not only cause overheating of the spectators' soul but also of the cables, which are also subjected to extreme stresses: their protective sheath must be as resistant as the skin of an elephant . And they must be flexible, robust, easily rollable, crush-resistant and able to withstand countless uses. The special ELEPHANT SPM4025 combined cable is one of the outstanding models designed specifically for woofer and surround systems. The SPM4025 consists of a total of 4 conductors with a cross-section of 2.5 mm². Due to its wiring mode similar to that of hi-fi drivers, the SPM4025 delivers absolutely pure treble and faithful and dynamic bass.
Make a comparison with other cables for speakers: the ELEPHANT will convince you in all areas!
Also available in FRNC version without halogen(test C) and version E30!
https://www.audiophonics.fr/images2/722/SOMMERCABLE_ELEPHANT_SPM425_1.jpg
ADVANTAGES:
  • Transmission of signals without loss, thanks to specially formed cores
  • Very flexible, suitable for stage installations (PVC version only), easily rollable
  • Compatible with common Neutrik-Speakon connectors
  • Easy transformation thanks to the excellent insulation and numbering of the cores
USE:
  • Professional Acoustic Equipment / Output Amp
  • Surround and woofer systems
  • Fixed building installations
Technical characteristics:
Constitution
(4LIY2.5mm 2 ) Y
r "> Envelope, diameter
PVC 10.2 mm
AWG
13
Number of Conductors
4 x 2.5 mm 2
Envelope material, insulation
HM2 (C mode halogen free) PVC
Copper strands per core
78 x 0.20 mm
Conductor insulation, diameter
3.05 mm
Operating temperature
min. -25 ° C
max. 70 ° C
Fire resistance per m
0.49 kWh
Weight per m
160 g
Color of envelope
black
Packaging, packaging unit
per meter
Electrical Specifications:
Odometer Resistance, Conductor
<7.7 Ohm
Resistance, insulation
> 5 MOhm
Operating voltage
max. 300 V
Test voltage
2 kV
Reference No. </ Span>
490-0051-425
Diameter (mm)10.2
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
ShieldingNo
Section (mm²)2.00
Ground / ShieldingNo
4 reviews
Fait son job.
Utilisé sur une installation haut de gamme tri amplifiée: fait parfaitement son job.
This review has been posted for SOMMERCABLE ELEPHANT SPM425 HP OFC cable 4x2.5mm² Ø 10.2mm
Aucune reserve d'aucune sorte
Qualité du câble, de la gaine, du montage, du marquage. ça sonne comme un 2x2,5 de très bonne qualité. L'utilise en 8x2,5 et en 4x2,5. Excellent. Pour le reste, Je laisse les PRO du U n'est pas égale à RI s'exprimer sur le 'SON' des câbles.
A acheter sans réserve .
Au prix proposé ce petit câble ne paie pas de mine . J'ai relié les 4 câbles de 2.5 mm 2 par 2 pour n en faire que 2 de 5 mm carré . Ce montage permet d'annuler le champ magnétique . A l écoute stupeur ! Je connais bien Sommer câble j'utilise l'albédo régulièrement et encore une fois il son à la hauteur de leur réputation .
 (4)
un peut juste
Pratique mais un peut juste pour de la haute fidélité, enfin les performances de ce câble coresspondent à son prix.
