VIABLUE SC-6 HP Copper Cable OCC / Silver 15mm² Ø 26mm
Reference : 6327
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2025.
The ViaBlue ™ SC-6 AIR Silver speaker cable carries six individual cores in a circular layout. The spatial separation of individual drivers is created by the ViaBlue Airpipe.
In this way the existing range of distances between the different frequency ranges that occur in the signal transmissions are drastically reduced and allow a totally real and effective sound.
This complex wiring system consists of a total of 36 (6x6) signal conductors of 5.5mm diameter (684 individual strands) with a total cross-sectional area of ​​15mm ² and 10 AIRpipe specially designed to provide a total diameter of 26 mm.
The SC-6 AIR Silver cable has 6 main conductors for all imaginable applications such as single-wiring, bi-wiring, bi-amplification and tri-amplification.
Each of the six main conductors is divided into six sub-conductors, which are arranged in a circle around an Airpipe.
By dividing the sub-conductors in a circle, a very low capacitance of about 98 pF / m is obtained which is a prerequisite for a fast and complete signal transmission as well as preventing the load from being cached in the cable himself.
The whole system is protected by a cable and a flexible and satin sheath.
The SC-6 AIR Silver cable delivers impressive sound, even over long distances, thanks to virtually lossless transmission of audio signals.
Diapason d'Or for the Viablue SC-6
" At the prices at which these cables are offered, the gain is significant, indisputable and totally justified. A nice discovery of a know-how from the other side of the Rhine. "
Diapason d'Or pour le Viablue SC-6
Diameter (mm)26.0
Number of conductors6
Insulation materialNC
ShieldingYes
Section (mm²)15.00
Conductors material (Cable)Silver
Ground / ShieldingNo
6 reviews
Gros câble aux multiples possiblités
J'ai acheté ce câble pour sa modularité. Je l'ai pris non monté pour pouvoir choisir le nombre de brin de cuivre OCC que je voulais et de cette manière l'adapter à mon système audio pour ne pas avoir un son où les basses ne seraient pas maitrisées. Contrat rempli !
Un son ample, des médiums présents mais non criard, des aigus détaillés et des basses qui ne bavent pas.
A titre d'exemple, la totalité des brin, chez moi, donne des basses trop présentes et non maitrisées. Avec un reclocker, 4 brin de cuivre et sans clock 3 brin de cuivre. Je sais que lorsque je changerai mon ampli, je pourrai changer la connexion du câble. C'est donc vraiment bien.
This review has been posted for VIABLUE SC-6 HP Copper Cable OCC / Silver 15mm² Ø 26mm
cable
Excellent câble que j'utilise depuis son achat dans le grave en remplacement d'un câble pur cuivre industriel. La voie a retrouvé un tonique et un naturel remarquable, améliorant l'image sonore et l'ambiance ds enregistrements "live". diamètre imposant mais assez facile à dénuder.
wrong description
Be careful as this isn't a OCC silver/copper cable!!!
Hard to beat features.
I purchased four meters of SC-6 for two 2 meter cables. I also got T6s forks, SC-AIR Spliters and Viablue sleeve to complete the set. Ironicaly, Viablue does not sell a 2 meter pair (1.5m, 3m, etc). All were delivered to me in the U.S. without problems.
The features of this cable are as good as anything you'll find, if you like silver-plated OFC copper, air pipes, and litz configurations. Preparing, dressing and terminating the cable will be a long, tedious process because of the cable's complexity. However, it's not difficult at all for the avid DIYer. With that in mind, I think purchasing a 'ready-made' pair would be a better value given the amount of time it takes to prepare it's many individual conductors for termination.
Le câble parfait ?
Câble acheté en remplacement d’un produit low-cost mais en bi-câblage quand même. Montage également en bi-câblage et relativement facile avec tous les composants du même fabricant (splitters, gaine et fiches banane à souder). Attention toutefois à la longueur de la gaine, un coefficient de 1,5 minimum est requis compte tenu du diamètre conséquent de ce câble. Une période d’une trentaine d’heures est nécessaire pour que ce câble révèle tout son potentiel. Utilisé entre un ampli Denon PMA2500NE et des enceintes Klipsch Heresy 3, il se révèle exceptionnel : aigus clairs, cristallins sans jamais être agressifs, médiums bien charpentés, présents et très justes, basses très tendues et nuancées. Un câble très équilibré et sans coloration. La scène sonore c’est élargie et la profondeur est apparue tout en conservant cette dynamique que j’apprécie. Bref, que du très bon pour un prix très raisonnable. Association avec du Klipsch plus que recommandable à mon humble avis
