Connector
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
Jean Louis d.
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une...
Binding Posts & Terminals
Discover our range of speaker terminals, alone or mounted on a plate, for the design of your speakers or HiFi amplifiers.
  • Binding Posts
    Binding Posts
    Discover our range of speaker terminals (without mounting plate) for the design of your speakers or amplifiers.
  • Speaker terminals
    Speaker terminals
    Discover our range of speaker terminals mounted on plates or mounting brackets, for the design of your HiFi speakers.
