EIZZ EZ-403 Gold plated Speaker Binding posts (Pair)
These speaker / amplifier binding blocks feature an extended screw ideal for thick panel mounting and can be installed on facades with thickness from 0.8mm to 38mm.
Reference : 15321
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 06-02-2025.
EIZZ EZ-403
Gold plated speaker binding posts  (Pair)
Their brass body is 24K gold plated with a thickness of 3U "to provide excellent connectivity and protect connectors from wear and oxidation.
The connector body is ?8mm in diameter with 11mm translucent POM insulation.
SPECIFICATIONS
TypeSpeaker Binding post
DiameterBody: ⌀8mm
Isolator: ⌀11mm
Max panel thickness38mm
Body materialBrass
PlatingGold
Sold byPair :
1x black binding post
1x red binding post
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)38
Accepts Banana PlugsYes
ConnectorSpeaker terminal
These speaker / amplifier binding blocks feature an extended screw ideal for thick panel mounting and can be installed on facades with thickness...
