ELECAUDIO BP-208 Gold plated isolated Binding post (Pair)
Reference : 11153
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 16-04-2025.
Here is a pair of ELECAUDIO resolutely HiFi loudspeaker terminal made of transparent plastic, all the contacts of which are integrally Gold plated 24K. Connection system via terminal, or by welding if required.
Accepts large diameter cables via one fully insulated burial system , as well as banana sheets.
Specifications:
  • Acrylic Insulation
  • Suitable for panels up to 15mm thick
  • Contacts Plated Gold 24k
  • Drilling max : 11.5mm
  • Maximum Internal Diameter of Cable: 5.50mm
  • External Maximum Cable Diameter: 7.50mm
  • Thread Diameter: 8.60mm
  • Diameter of Insulation Washer: 16mm
  • Weight:31g / Unit
  • Sold in pairs: A red, and a black
ELECAUDIO Bornier Plaqué Or 24K
(Illustration with a pod (not included))
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)15.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
bornier
j avais décide de changer ,mes borniers de mes 3 paires de cabasse pour mettre des fiches bananes, sans percer ou rien transformer et garder les originaux .
ils sont très bien rempli le montage.
This review has been posted for ELECAUDIO BP-208 Gold plated isolated Binding post (Pair)
