Isolated Red Copper Binding Post Cryogenic Treatment (Pair)
These RCS CC terminals feature 99.998% pure Red Copper contacts for near-perfect conductivity, and a body with Nylon dielectric. Like the vast majority of CC connectors, RCSs benefit from cryogenic processing to maximize signal conductivity and stability. Mounting your speakers in the body is simple since the cables can be either welded or screwed. In addition, these terminals accept either bare wire, banana plugs or forks.
Product type | Binding posts |
Contacts material | Red Copper |
Dielectric | Nylon |
Internal connection type | To solder or to screw Max cable diameter Ø3.5mm |
External connection type | Bare wire (Max diameter Ø4.5mm), bananas, spades |
Length | 60mm |
Max panel thickness | 22m |
Cutout diameter | Ø10.5mm |
Quantity | Sold per pair |
