CC RCS Isolated Red Copper Short Binding Post Cryogenic Treatment (Pair)
These RCS S CC terminals feature 99.998% pure Red Copper contacts for near-perfect conductivity, and a body with Nylon dielectric. Like the vast majority of CC connectors, RCSs benefit from cryogenic processing to maximize signal conductivity and stability.
Reference : 13813
16,90 €tax incl.
14,08 € tax excl.
CC RCS S
CC RCS S Borniers Court Cuivre Red Copper Isolés Traitement Cryogénique
These RCS S CC terminals feature 99.998% pure Red Copper contacts for near-perfect conductivity, and a body with Nylon dielectric. Like the vast majority of CC connectors, RCSs benefit from cryogenic processing to maximize signal conductivity and stability. Mounting your speakers in the body is simple since the cables can be either welded or screwed. In addition, these terminals accept either bare wire, banana plugs or forks.
These terminal blocks differ from the CC RCS models in length. They are indeed shorter.
Product typeBinding posts
Contacts materialRed Copper
DielectricNylon
Internal connection typeTo solder or to screw
Max cable diameter Ø3.5mm
External connection typeBare wire (Max diameter Ø4.5mm), bananas, spades
Length52mm
Max panel thickness9.5m
Cutout diameterØ10.5mm
QuantitySold per pair
Mounting typeTo weld
Mounting typeTo screw
ConnectorBanana / Spade
These RCS S CC terminals feature 99.998% pure Red Copper contacts for near-perfect conductivity, and a body with Nylon dielectric. Like the vast...
