DAYTON AUDIO BPA-38N HD Binding Post Ø15mm x 57mm (Pair)
The Dayton Audio BPA-38N HD terminal blocks have been designed to contribute to good signal reproduction. The contact material is Satin / Nickel plated, ensuring excellent resistance to oxidation.
Reference : 18342
10,50 €tax incl.
8,75 € tax excl.
Shipping date: 22-04-2025.
Binding Post ⌀15mm x 57mm (Pair)
Dayton Audio BPA-38N HD Borniers plaqués Satin Nickel
In addition, these terminals can accommodate cables up to 3.26mm in diameter (8AWG) or banana plugs for an easier connection. The large diameter notched head allows easy grip for improved ergonomics.
The long screw pitch of the terminal block allows integration on panels up to 25.4mm thick. In addition, the notched part inside will prevent the connector from rotating on itself.
PlatingSatin / Nickel
Max panel thickness25.4mm
Cutout diameter6.35mm
Accepts banana plugsYes
Total length57mm
Max diameter15mm
Connection typeTo solder
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Contacts Plating (Connector)Nickel
The Dayton Audio BPA-38N HD terminal blocks have been designed to contribute to good signal reproduction. The contact material is Satin / Nickel...
