DYNAVOX Gold Plated Binding Post ⌀17mm x 22mm (Pair)
These affordable, gold-plated Dynavox binding posts are ideal for DIY design or replacement of old terminal blocks. These accept banana cards.
4.0 / 5
Reference : 12511
9,90 €tax incl.
8,25 € tax excl.
DYNAVOX Terminals
Gold plated ⌀17mm
Dynavox borniers haut parleur
These affordable Dynavox terminal blocks feature a gold-plated plating for good conductivity and resistance to oxygenation. They are ideal for DIY design or replacement of old terminal blocks. The nut allows efficient tightening on the panel and a washer provides insulation. In addition, these terminals accept banana plugs for quick and easy interconnections.
Max dimensions (handles)⌀17 x 22mm
Screw thread dimensions⌀8.8 x 12mm
Cable diameterMax. 5mm
Accepts banana connectorsYes - 4mm
Mounting typeTo weld
Accepts Banana PlugsYes
The bindings posts were purchased to fit in Dayton Audio bi-wired binding post. The products fit OK.
The binding posts will be used with banana plugs and works just fine. When applying the speaker cable by using screwing down I would choose a different binding post
This review has been posted for DYNAVOX Gold Plated Binding Post ⌀17mm x 22mm (Pair)
