Isolated Binding Posts Gold Plated Ø18 x 48mm (Pair)
These binding posts have gold-plated copper alloy contacts, ensuring good signal conductivity and resistance to oxidation. They accept both bare wires and banana plugs. They also benefit from a modern design with a carbon body.
Product type | Binding posts |
Contacts material | Copper alloy |
Contacts plating | Gold |
Max cable diameter | Ø5mm |
Banana plug compatibility | 4mm |
Internal connection type | To solder |
Total dimensions | 48 x Ø18mm |
Cutout diameter | Ø8.8mm |
Quantity | Sold by pair |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
