ELECAUDIO BP-202 24k Gold Plated Acrylic Insulation Terminals (Pair)
Reference : 7629
7,90 €tax incl.
6,58 € tax excl.
Here are the ELECAUDIO BP-202 products, a pair of transparent plastic loudspeaker terminals, the contacts of which are fully plated with fine 24k gold, which ensures a flawless conductivity of the signal.
These terminals accept large diameter cables (up to 5mm) via a totally insulated burial system, as well as banana plugs. The insulation washer is additionally provided with a key.
Features:
  • Gold-plated connector with acrylic insulation
  • Gold plated 24k
  • Maximum internal diameter of cable: 5 mm
  • Maximum cable outer diameter (HP): 5 mm
  • Diameter of Insulation Washer: 5mm
  • Panel thickness: 2mm to 10mm
  • Maximum connector diameter: 21mm
  • Not compatible with forks
  • Sold in pair (one Red and one Black)
https://www.audiophonics.fr/images2/7629/7629_borniers_elecaudio_thumbs.png
https://www.audiophonics.fr/images2/7629/7629_borniers_elecaudio_1.jpg
https://www.audiophonics.fr/images2/7629/7629_borniers_elecaudio_2.jpg
Mounting typeTo weld
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Belle connexion
Très bon produit, bien construit et efficace dans sa mise en œuvre et dans son utilisation. Excellent rapport qualité prix.
This review has been posted for ELECAUDIO BP-202 24k Gold Plated Acrylic Insulation Terminals (Pair)
