ELECAUDIO BP-205 Isolated Acrylic Terminal Block Gold Plated V2 (Red)
Reference : 4766
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
Transparent plastic loudspeaker terminal block with integral contacts gold plated end 24k .
Accepts large diameter cables via one fully insulated burial system , as well asbanana sheets.
Insulating washer with key. Screw terminal block .
Specifications:
  • Acrylic Insulation
  • contactsPlated Gold 24k
  • Maximum Internal Diameter of Cable: 5.50mm
  • External Maximum Cable Diameter: 7.50mm
  • Thread Diameter: 8.50mm
  • Diameter of Insulation Washer: 11.30mm
  • Panel Thickness:2.50mm to 15.50mm
  • Max external diameter: 19mm
  • Unit weight :30g
  • Color:Red (also available in Black)
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)15.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
terrible pour un assemblage DIY
Le bricolage est compliqué avec ceux-là, la rondelle isolante possède un élément gênant, il faut l'enlever avec un cutter ! Sinon la douille PVC ne peut pas rentrer dans le trou, c'est dommage que ce ne soit pas précisé dans le descriptif !
This review has been posted for ELECAUDIO BP-205 Isolated Acrylic Terminal Block Gold Plated V2 (Red)
