ETI BP-50C Speaker Terminal Gold Plated Pure Copper Ø19mm (Pair)
The ETI BP-50C are very high performance speaker terminals at a contained price.  Made of a 1100 Series Hardened Copper conductor with an IAC of 102% (conductivity index), these terminals ensure an audio signal that will not be degraded.
Reference : 14378
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 23-04-2025.
ETI BP-50C
Speaker Terminal Gold Plated Pure Copper (Pair)
ETI BP-50C Borniers Cuivre Pur Plaqué Or (La paire)
In addition, the BP-50Cs have a gold plating, applied without the use of Nickel. While many manufacturers use Nickel prior to gold plating to provide a brighter finish, this also reduces conductivity and therefore the quality of the audio signal.
On the structure side, these terminal blocks are equipped with an Aluminium body and Polymer bushings. The Polymer ring allows to have no conductive material in contact with the Copper, and the Aluminium is an excellent material to reject EM / RF noise that could disturb the signal.
It's easy to assemble. While you can of course fix your cable by soldering, the BP-50C also offers a screw fixing system for easy mounting.
ETI opts here for a 50mm long post, allowing a large contact area between the terminal block and the conductor of your cable. The nut used to fix the terminal blocks is made of a non-conductive high density polymer, so that no conductive material touches the copper post, except your cable.
Product typeSpeaker terminals
Conductor materialPure Copper (IACS 102%)
Contacts platingGold
Body materialAluminium
Polymer
Post length50mm
Cutout diameterØ11.6mm
Connection typeTo scresw / To solder
Max cable diameterØ4.3mm
Max panel thickness28mm
Total dimensionsØ19 x 78mm
Case (for one terminal)25g
ColorBody : Black
Marking rings : Red and Black
PackagingSold by pair
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)28.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
2 reviews
Son magnifique et transparent
Je confirme c'est top
Cuivre only
This review has been posted for ETI BP-50C Speaker Terminal Gold Plated Pure Copper Ø19mm (Pair)
Très bon bornier
Laisse tout passer
De très bonnes qualités
The ETI BP-50C are very high performance speaker terminals at a contained price.  Made of a 1100 Series Hardened Copper...
