ETI KRYO Silver Plated Tellurium Copper Binding Post Ø17mm x 52mm (Set x4)
The ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and durability.
Reference : 12787
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 23-04-2025.
ETI KRYO Binding Post
Silver plated Tellurium Copper ⌀17x52mm (Set x4)
ETI KRYO Borniers Cuivre Tellurium Plaqué Argent
These ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and durability.
For the connector body, ETI uses Brass and Polymer assembly, the latter allowing an efficient separation with the conductor, in order not to disturb the signal, while allowing an efficient maintenance of the cables. Furthermore, this structure also reduces vibrations but also repels EMI/RF interference.
Finally, the connector receives cryogenic treatment in the USA, giving it even higher performance.
Conductor materialTellurium Copper
PlatingSilver
Housing materialBrass / Polymer
Max length52mm
Max diameter17mm
Drilling diameter11.3mm
Max panel thickness9mm
Connection typeTo screw / To solder
Max cable diameter4mm
Sold by 42x White / 2x Red
Weight (for one binding post)25g
ColorsBlack + Red / Black + White
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)9.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Contacts Material (Connector)Tellurium Copper
Excellents borniers
Difficile de faire mieux : plus performant selon moi que les WBT ou même les Furutech.
Pratique d'utilisation car sans soudure, c'est un sans faute, parfait !
This review has been posted for ETI KRYO Silver Plated Tellurium Copper Binding Post Ø17mm x 52mm (Set x4)
The ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver...
