FURUTECH FT-818 (R) Speaker Terminals Rhodium plated Copper (Pair)
Furutech terminal blocks have been developed with the aim of satisfying the most demanding consumers.
They are made in Japan from pure copper and Alpha treated (cryogenization + demagnetization).
The advantage of copper over brass is better conductivity as well as higher magnetic resonance frequency.
By buying this product you get 141 loyalty points
Reference : 10415
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 24-04-2025.
FURUTECH FT-818 (R)
Rhodium plated pure copper Speaker Terminals (pair)
FURUTECH FT-818 (R) Borniers Cuivre pur plaqué Rhodium (La paire)
Brass is easier to machine but its resonant frequency is 22kHz, which is very close to the audio spectrum and can cause unpleasant auditory sensations.
These terminal blocks are also available in gold plating.
SpEcifications
Product typeSpeaker Terminals
Conductor materialα (Alpha) Treated Pure Copper
Conductor platingRhodium
Housingcarbon fiber, non-magnetic stainless steel
InsulationNylon (red/white) and polycarbonate
ConnectionsTo solder or to screw
Max. cable diameter4,5mm
Dimensions 74.6x37.4mm
PackagePair
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Furutech terminal blocks have been developed with the aim of satisfying the most demanding consumers. They are made in Japan from pure copper...
