Gold plated Binding posts Ø6,5mm (Pair)
3.8 / 5
Reference : 11721
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 06-05-2025.
Here is a pair of speaker terminals (red and black) for DIY applications and assemblies. These are gold plated, and compatible with banana plugs, forks, and even bare wires.
Characteristics :
  • Red and Black Terminal Blocks
  • Gold plated
  • Material: Brass
  • Short thread
  • Overall Length of Connector: 32mm
  • Thickness max. of panel: 3mm
  • Drilling Diameter: 6.5mm
  • Acceptable Cable Diameter: 5mm
  • Total diameter of a plug: 15mm
  • Compatible banana plugs, forks, and bare wires
  • Welding
Mounting type
  • To weld
Connectic
  • Female
Connector
  • Speaker terminal
Accepts Banana Plugs
  • Yes
Max panel thickness (mm)
  • 3.0
Contacts Material (Connector)
  • Copper Alloy
Contacts Plating (Connector)
  • Gold
4 reviews
Price/Quality acceptable
First I want to thank Audiophonics for the excellent customer care service and for the fast shipping.
Be aware of the dimensions, (I wasn't) they are quite small, the nut, the grover and the existed piece for soldering the wire are not usable ... they contain iron (easy magnetized), the rest seems to be ok, made from brass with no magnetic properties, as in title price/quality acceptable
This review has been posted for Gold plated Binding posts Ø6,5mm (Pair)
bon rapport qualité prix
Good looks but bad material
These are from some kind of alloy with bad conductivity, not copper. Gold plating is not enough to conduct such high currents. Look for a real copper terminals.
Pratique et esthétique.
Ce n'est pas la première fois que j'adapte ces borniers à des enceintes. Notamment d'anciennes JBL, ils sont parfait, une installation sans contrainte à la portée de tous. Bien lus pratique que ceux d'origines et permettent un câblage de grosse section ou carrément des fiches "bananes".
