JANTZEN AUDIO Speaker Terminals Carbon (Pair)
These carbon-finish speaker terminals can be easily mounted with a screw system. They can accept cables up to 4mm in diameter. They also accept banana plugs for a quick connection of your speakers to your amplifier, or bare wires up to 4.3mm in diameter.
Reference : 15168
17,90 €tax incl.
14,92 € tax excl.
Jantzen Audio Speaker terminals
Jantzen Audio Borniers enceintes carbone (La paire)
Product typeSpeaker terminals
Speaker terminals finishCarbon
Total length67mm
Max cable diameter (internal side)Ø4mm
Mounting typeTo screw
To solder
Banana plugs compatibility
Max panel thickness27mm
Screw thread diameterØ7.7mm
Cutout diameterØ12mm
Weight (pair)82g
QuantitySold by pair (one with black ring, one with red ring)
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
bornier
très bon bornier facile d'instalation je recommande pour un budjet raisonnable
This review has been posted for JANTZEN AUDIO Speaker Terminals Carbon (Pair)
These carbon-finish speaker terminals can be easily mounted with a screw system. They can accept cables up to 4mm in diameter. They also accept...
