KLEI NAKED HARMONY Binding Posts Copper (Set x4)
The KLEI Naked Harmony are top-of-the-range, high-performance binding posts. First and foremost, they feature pure copper contacts, offering optimum conductivity of 101% IACS.
Reference : 19940
124,00 €tax incl.
103,33 € tax excl.
Shipping date: 24-04-2025.
KLEI Naked HarmonyBinding Posts Copper (Set x4)
Photo of KLEI NAKED HARMONY
The KLEI Naked Harmony are top-of-the-range, high-performance binding posts. First and foremost, they feature pure copper contacts, offering optimum conductivity of 101% IACS. The special design of these binding posts also enables them to preserve signal integrity by eliminating certain interferences such as eddy currents and capacitive reactance. Their body is made of a special polymer, highly resistant to high temperatures, and their carefully calculated mass limits skin effect and EMI/RFI interference.
These binding posts accept 4mm banana plugs, forks and even 3mm bare wire, thanks to an innovative system that prevents shearing of the latter. Internal assembly is by soldering. These speaker terminals are ideal for high-end DIY projects.
Product typeBindind posts
Contact materialCopper
IACS Conductivity index> 101%
Accepted connection typeØ3mm bare cable
Banana plug Ø4mm
Forks
Mounting typeTo weld
Mounting holeM8
Total length50mm
Total diameterØ17mm
Max panel thickness10mm
Body cut-out diameterØ8mm
Identification color
PackageSet x4
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
The KLEI Naked Harmony are top-of-the-range, high-performance binding posts. First and foremost, they feature pure copper contacts, offering...
