MONACOR BP-405G Screw-in Speaker Terminals Gold Plated (Pair)
3.0 / 5
Reference : 1500
9,50 €tax incl.
7,92 € tax excl.
Shipping date: 24-04-2025.
Dimensions schema BP-405G
Monacor speaker terminals
Pair of speaker terminals. Rigid brass construction with gold plated connector. These terminals can be screwed or plugged in. They accept banana plugs or conductors up to 5mm diameter. Can be mounted on rigid plastic or wood supports. Solder connection.
The terminal blocks are not insulated.
sPECIFICATIONS
Product typeSpeaker terminal
UsageTo screw / To plug
Quantity2
PlatingGold
Color codeBlack / Red
Operating temperature range0-40°C
Weight29g (pair)
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Qualité décevante
Le placage est mal fait, il y a quelques traces qui ressemblent déjà à de l'oxydation. Il y a du jeu dans les pas de vis. Bref, qualité assez médiocre.
This review has been posted for MONACOR BP-405G Screw-in Speaker Terminals Gold Plated (Pair)
