MUNDORF MCONNECT TPCU670SC Speaker Terminals OFC Copper Silver Plated Ø6mm (Pair)
Mundorf MConnects terminal blocks have been developed with the aim of satisfying the most demanding consumers. They are manufactured in Germany from OFC Copper with Silver plating for optimum conductivity.
Reference : 3324
89,00 €tax incl.
74,17 € tax excl.
Mundorf Mconnect TPCU670SC
Speaker Terminals Silver Plated OFC Copper Ø6mm (Pair)
Mundorf Mconnect TPCU670SC Borniers 6mm Cuivre OFC Plaqué Argent (La paire)
The advantage of Copper over Brass is better conductivity and a higher magnetic resonance frequency. Brass is easier to machine but its resonance frequency is 22KHz, which is very close to the audio spectrum and can cause unpleasant hearing sensations.
Mundorf Mconnect TPCU670GC Borniers 6mm Cuivre OFC Plaqué Or (La paire) Mundorf Mconnect TPCU670GC Borniers 6mm Cuivre OFC Plaqué Or (La paire)
Product typeSpeaker terminals
Contacts materialOFC Copper
PLatingSilver
Insulating bodyABS Plastic
Screw thread diameterØ6mm
Cutout diameterØ9mm
Total diameterØ20mm
Total length71.8mm
Max panel thickness24mm
Compatible with banana plugs / forks connectors
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)24.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Mundorf MConnects terminal blocks have been developed with the aim of satisfying the most demanding consumers. They are manufactured in Germany...
