Mundorf Mconnect TPCU870E Terminal Blocks EVO 8mm Pure Copper OFC (pair)
Reference : 7202
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 23-04-2025.
The new EVO Mconnects Mundorf terminals have been developed to satisfy the most demanding consumers.
Mundorf terminal blocks are manufactured in Germany from solid copper.
The advantage of copper over brass is better conductivity and a higher magnetic resonance frequency.
Brass is easier to machine but its resonant frequency is 22KHz, which is very close to the audio spectrum and can cause unpleasant hearing sensations.
Features:/ Strong>
  • Conductor: Copper OFC
  • Plating:
  • Insulating body: ABS plastic
  • Panel Drilling Diameter: 14mm
  • Total Terminal Block Diameter: 20mm
  • Overall Length of Terminal Block: 76mm
  • Maximum Panel Thickness: 3mm
  • Accepts forks of: 7mm
  • Compatible with 4 mm banana plug
https://www.audiophonics.fr/images2/6384/6384_TPCU870GE.jpg
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)3.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
