PCB Connectors for Banana Plugs Silver-Plated 4mm (Pair)
These PCB sockets for banana plugs have silver-plated copper alloy contacts with PA Nylon insulation and accept conventional Ø4mm banana plugs. Their distinctive feature is that they take up very little space, and feature lateral grooves that allow them to be nested for optimum space-saving.
Reference : 18511
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 24-04-2025.
PCB Connectors for 4mm Banana Plugs Silver-Plated (Pair)
These PCB sockets for banana plugs have silver-plated copper alloy contacts with PA Nylon insulation and accept conventional Ø4mm banana plugs. Their distinctive feature is that they take up very little space, and feature lateral grooves that allow them to be nested for optimum space-saving. They are therefore ideal for compact DIY projects, or for multi-channel DIY projects where space saving may be an important factor.
Product typePCB sockets for banana plugs
Contact materialCopper alloy
Contacts platingSilver
InsulationPA Nylon
Mounting typeTo weld
Panel mounting holeØ9.5mm
Max. panel thickness2mm
IdentificationBlack and red
Max voltage/current250V AC 24A max.
Total dimensions23.3 x 10.5 x 19mm
Net weight4g/banana plugs
PackageSold by pair
ConnecticFemale
Max panel thickness (mm)2.0
Accepts Banana PlugsYes
ConnectorBanana
These PCB sockets for banana plugs have silver-plated copper alloy contacts with PA Nylon insulation and accept...
