These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of 24k gold-plated copper alloy, ensuring excellent conductivity and resistance to oxidation. They accept cables up to Ø6mm in diameter, and are easy to install thanks to a screw-on system.
Product type | Speaker terminals |
Contacts material | Copper alloy |
Contacts plating | Gold 24k |
Max conductor diameter | Ø4mm |
Mounting type | To screw |
Cutout diameter | Ø11.5mm |
Total dimensions | Ø19mm*65mm |
Quantity | Pair (one terminal block with red ring, one terminal block with white ring) |
Mounting type |
Connectic |
Max panel thickness (mm) |
Accepts Banana Plugs |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
