VIBORG BP-604 (G) Binding Post Silver / Gold Plated 24K 5µ Pure Copper Ø4.5mm (Set x4)
The BP-604 (G) from Viborg are excellent terminal blocks, ideal for high quality DIY mounting. Indeed, they integrate a pure copper conductor in order to offer an optimal conductivity of the signal as well as a triple plating Copper OFC, Silver and Gold 24K.
Reference : 12771
119,00 €tax incl.
99,17 € tax excl.
VIBORG BP-604 (G)
Binding Post Silver / Gold Plated Pure Copper (Set x4)
Viborg BP-604G Borniers
The BP-604(G) from Viborg are excellent terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity. With the same aim of maximizing signal quality but also protecting the connector from oxidation, the terminal contacts have triple OFC Copper, Silver and Gold plating. In addition, the terminal block has Nylon and Polycarbonate insulation to protect the signal from potential interference.
In addition, this model has a body based on carbon fiber, POM and copper alloy giving it a strong design.
Conductor materialPure copper
3 Layered Plating1. OFC Copper
2. Silver
3. Gold 24K 5µ
Housing materialCarbon fiber, POM, copper alloy
InsulationNylon
Polycarbonate
Connection typeTo screw / To solder
Acceptable cable diameter
Drilling diameter11.45mm
Housing dimensions11.5 x 23.4mm
Total length54mm
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)11.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Borniers Viborg
Je suis trés satisfait de mon achat. Ces borniers sont de trés bonne qualité, bien meilleurs que mes borniers dorigine triangle antal Ez. Serrage puissant, ouverture du son grâce à la bonne qualité des connecteurs. N'utilisant pas la double amplification ou le double câblage j'ai supprimé les borniers graves et réuni le cablage interne grave et aigu sur les borniers viborg avec les vis de serrage.
Moins de connections = moins de pertes, amélioration du son incontestable dans mon cas.
Serrage du câble sommercable sc-dual blue directement dans le bornier, il est parfaitement bloqué.
This review has been posted for VIBORG BP-604 (G) Binding Post Silver / Gold Plated 24K 5µ Pure Copper Ø4.5mm (Set x4)
The BP-604 (G) from Viborg are excellent terminal blocks, ideal for high quality DIY mounting. Indeed, they integrate a pure copper conductor in...
