VIBORG BP-614 Binding Posts Pure Copper Ø4.5mm (Set x4)
These Viborg BP-614 terminal blocks ensure excellent conductivity thanks to their high-performance pure copper contacts. They accept conductors up to a diameter of 4.5mm and can be easily mounted with a locking screw.
Reference : 14451
149,00 €tax incl.
124,17 € tax excl.
Viborg BP-614
Viborg BP-614 Bornier Cuivre Pur Ø4.5mm (Set x4)
These Viborg BP-614 terminal blocks ensure excellent conductivity thanks to their high-performance pure copper contacts. They accept conductors up to a diameter of 4.5mm and can be easily mounted with a locking screw. The terminal blocks also benefit from a modern design with an attractive carbon coating.
Product typeBinding posts
Contacts materialPure Copper
Body materialsCarbon fiber
POM
Eutectic Copper alloy
Insulation materialsNylon (red/black rings)
Polycarbonate (transparent ring)
Mounting typeTo screw
Max. cable diameterØ4.5mm
Body dimensionsØ11.5 x 23.4mm
Total length72mm
ColorCarbon
QuantitySold in sets of 4
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
These Viborg BP-614 terminal blocks ensure excellent conductivity thanks to their high-performance pure copper contacts. They accept conductors up...
